Chevy truggy (no drivetrain)
silveradoreb
Boone,NC
I have an NC title in hand
Body/Cage
Narrowed front end, custom bumper from Diy4x (no winch). Warn hi/low beam lights, custom grille, professional built cage inside and outside(1.75" .120 wall DOM). LED tail and reverse lights, boatsided with UHMW skins and DOM tubing. Lexan windshield, UWS toolbox , 20 gallon aluminum fuel cell.
Interior,
Suede quick release steering wheel, Beard Seats, crow harnesses attached to cage. Custom aluminum dash with autometer guages and moroso switch panel, art carr shifter for a TH400.
Suspension
Around 4” of lift. Skyjacker springs front, BDS springs in the rear (52”) with DIY4x shackle flip. Skyjacker shocks all around.
Truck is setup for 1 ton axles, it has an orbital valve mount and borgeson steering shaft for full hydro. wheel base is 112" It clears 42's fine
$1,000
Heavy duty driveshafts are also included. the rear is a 1410 on both ends and the front is a 1350 and a cv.
do you want to sell that 1350 driveshaft seperate?
pat
At this point not right now. its going to be alot of aggravation to sell things off of it. I am trying to sell it all at once and see how it goes, I will let you know if I decide differently though
