Cigar lighter removal help
You have hold the socket part and turn the back side sleeve.
That one is going to need some penetrating oil, spay, TAP with small hammer, let it sit. (WD-40 is not penetrating oil)
If you want to save it not sure how grab inside socket, if going to trash it use a smaller flat blade screwdriver to wedge in the side slots while try to turn the back
Correct. The whole outer sleeve threads backwards off of the inner sleeve.
