Clunk/knock on shutdown-6.2...
uglytruk
IN A JUNKYARD, UNDER A TRUCK*N E Rust Belt
A new noise developed recently in my '87 'Burb. 170k, but well maintained, exc. oil press. When I crank 'er and let go of the key before it starts, or when I turn it off, it clunks/knocks just as the engine stops turning. This is hot or cold, no matter. I thought it was the flywheel to TC, but tight/rings. Rotated and checked FW to crank. Not engine mount, def internal.
It makes this noise consistently. I now believe it's coming from the front/timing area? Any ideas?
I wonder if I could post/link a short video w/sound?
I don't know. I had the converter go on my 700R4 a few years ago. It made some terrible noise (but still functioned). The noise would disappear when the converter clutch would lock up. Not that this info really helps (400 converts don't lock up).
