Co2 regulator brand
jp0863
clovis, ca
I have had a Co2 tank for several years and was using an off the sheft regulator with gauges. Well it's time for a replacement. Was looking at Powertank high flow regulator, but they're way too expensive for what it is. Does anyone know where else to get a high flow regulator for Co2? I don't need gauges, just a preset one is fine, looking for about 120 to 150 psi and it's pretty much only used for tires.
do you want fixed or adjustable. You an pick up fixed 125 or 150psi for about 40 bucks.
I bave only used an impact with it. The hose will frost up about about 1 ft from the tank, but has never froze up on my. Ive used an air hammer also.
Do you meen froze up as in stopped working? This has never happened with mine.
I get one good pulse outta my impact an then regulator can't keep up even for short bursts. It is an off the shelf one from Airgas
