Confused about axles.
I would double check the width from axle flange to axle flange and make sure the wheel pattern is the same. If you are going 14 full float you should be fine
To answer some of your original questions, the wheel width is not a problem on any of these axles. I'm running a 1997 van axle in my Suburban, and aside from moving the perches it was a bolt-in swap. I'm running a 1978 C20 14bff axle in my Blazer, and it was a direct bolt-in swap. I prefer the van axles (Type "B" in the 14bff bible), as the brake drums are removable (most 14bff axles place the brake drums behind the hubs, so hub disassembly is required to service the brakes :doah:). Moving the perches is not difficult. I found that choosing the later axle cut my purchasing cost in half, as my yard had lots more cargo vans than they had square-bodied rigs (*and* I got the removable drums, too :D).
Turning radius should increase with wider axles, but somehow my (wide-axle) Suburban can still turn noticeably tighter corners than my stock K10 can. I don't have a good comparison of before vs. after, but it wasn't a noticeable difference. :dunno:
You shouldn't have to worry about the age of the axle if you are replacing the wearing parts. Seals & bearings will likely be the most worn components (more than the gears). Housing should last forever if it doesn't break outright (from abuse).
The only GM axle that I would specifically avoid is the 1/2-ton G80 (Gov-lock) axle. Those carriers like to fragment. But it sounds like that wasn't on your list anyway. The 14BFF is easy to work on, but heavy and it kills off some of your ground clearance. So it may or may not fit your purpose in that regard.
Are you replacing your front axle because you want different gearing? Or is there something else wrong with it?
Nothing wrong with front.
I would just be re-gearing and wanted to swap to 8 lug if I was swapping the back to 8 lug (Whole new $$ problem as my current set up is 6x6.5) I don't really want wheel conversion spacers.
Unless I found a 3.73 rear. The C20 is sold any how. Starting to become a tad bit dismayed as all upullandpay yards nearby don't seem to have my 3/4 ton bolt in! Made the drive out to aurora only to find the 85 k20 they supposedly had from website to be non existent (wooo... they gave me free upullandpay entrance tickets)
CL has not been fruitful yet either.
I want to get back to wheeling!
Is there some reason that you don't wanna grab a 6-lug 14bsf and keep the wheels you have? Moving the perches should take you less than an hour. I found it a whole lot faster than waiting for the right square-body to come along. 3/4-ton Cargo vans are everywhere. Or, if you really want the full-floater, 1-ton vans are even easier to find (in my area, at least). :dunno:
Whichever way you go, don't be dismayed. There are axles out there, and you'll be able to get back to wheeling just as soon as you find one. :waytogo:
I "think" the 2wd rear diffs have at least one shock mount that is different than 4x4's..
I like the 14 bolt SF axles for ease of brake repairs,the drum slides off like a 1/2 ton...a FF axle is beefier,but its more or a pain to get to the brakes...personally I haven't seen an SF axle break in street use,even hauling heavy loads,but I suppose anything is possible with huge tires & off roading..
I like the 14 bolt SF axles for ease of brake repairs,the drum slides off like a 1/2 ton...a FF axle is beefier,but its more or a pain to get to the brakes...personally I haven't seen an DF axle break in street use,even hauling heavy loads,but I suppose anything is possible with huge tires & off roading..
That's why I promote the later van axles. Modern, FUNCTIONAL brake drums! :woot:
imgp3972-jpg.160965
They're really nice, folks. :thumb:
Agreed, don't discount the semi floater. It's plenty beefy for most applications, weighs less, and has much better ground clearance. It's disadvantages is there's not as much aftermarket support for it as the FF, and it isn't ultimately as strong as the FF. I've been very happy with mine, I'm not worried about breaking it.
If youre rock crawling i wouldnt choose anything but a full float 14 bolt. Although SF is a very strong axle their big down side is what happens when they break. Ive wheeled with a 14sf...super strong but if it does break youll likely have a wheel laying next to your truck. Thats one of the big benefits of being full float, the axles are alleviated of the vehicles weight through using hubs. So even if you did brake a 14 bolt FF shaft you would still be able to roll around/get towed out/use FWD.
I do a tiny bit of rock crawling, mostly just trail riding. I'm new to the scene and just experimenting on what my truck can and can not do. This is where I damaged the rear dif (I hit the pumpkin on a rock here I believe)
The difference in price between SF and FF is pretty much 0 out here. Not sure about out there but its probably the same.
It seems that unless I go to bigger tires now, the loss of ground clearance might be detrimental with a larger pumpkin and only running 33s
I know that feeling! yeah to get full use out of the ff its really 37s or higher, however they can be shaved down easily. Probably knock 1.5 off the thing easy
