If done right, cribbing is just fine.
Martin
Martin
Looks like you have a good starting point.
1) Transfer case: Those trucks should both have NP208 transfer cases, but they probably have different input shafts (function of which tranny is in front of it). If so, you will hafta swap the shafts before you can swap them, but that should be all you need to do if you choose to do that swap. But what (specifically) is hard to shift?
Do you have any reason to rebuild your axles? Since you aren't talking about gear-swapping, and the axles appear to be in good shape, why would you bother pulling them apart?If you decide that you just hafta put in 6-lug shafts (or you want a locker), then you might as well go through the rear end, as you'll hafta open it up to remove the axle shafts. But you really don't have any reason to open the front unless you think there is a problem. Swapping from 6-->8 lugs (or vice versa) is easy on the front (only one step more than changing brake rotors, as the caliper backing plate also has to be changed). To explicitly answer your question, yes, the gears will swap into your existing front axle, but it is probably a bunch easier to swap axles and then install your 6-lug hubs & backing plates. No axle disassembly required. Unless you're wanting to replace bearings and seals pre-emptively.
Lockers. What is your purpose for this truck? A Detroit locker (and similar units) will be locked by default (can be good or bad depending on what you want to do). A positraction unit will not lock, but does feature some torque distribution. A factory gov-lock will be unlocked until slippage occurs and then lock up (like a Detroit) when needed. They're pretty neat units. The 10-bolt 1/2-ton gov-lock carriers like to fragment (), but the 14bsf and 14bff units seem to have a decent reputation. The truetrac is somewhere between the Detroit-style lockers and the clutch-style posi units. It will lock up, but defaults to being open. And evidently it doesn't always engage right away (search through the Garage section for a recent thread on this topic).
Martin
I went to attempt the swap today and ran into a little snag. I have (2) sets of 6 ton jack stands which were too short to reach the frame rails. (3 ton each... Kind of dumb that they are labeled 6 ton, but i digress)
So, I ended up swapping the bumpers instead! (Maybe I will be more inspired, now that I think it looks cooler)
I was researching prices of taller jack stands and was a little dismayed. I then came across cribbing. Is it safe? The idea would be to make a platform out of some 4x4s and rest the jackstand on top of it.
https://paulhasenmeier.wordpress.com/2011/12/05/cribbing-for-heavy-vehicle-lifting/
Am I just being cheap? There are tons of images online of people with lifted rigs and cribbing, but I will be under the vehicle and my life/limb is important to me.
The parking brake doesnt work on my main rig, but does on the donor.
1.) Transfer case: On the donor, when I shift from 2wd to 4hi, it is a smooth gliding feeling. When I shift in my rig, I have to yank down with moderate force to have it engage (about the same pressure as using a floor jack?)
Decided to just swap front/back axles for now based off responses. Seems like I will already be out of my comfort zone doing the swap ... let alone attempting to rebuild/regear axles. Another day for the rebuild, unless need necessitates. Ill keep the 8 lugs on my rig for now and see if I can source some cheap wheels or fork out 100ish per for my current ones (pro comp matte black D window.. ) Cheaper then buying new axle shafts @ 122 per .
Brakes kinda sucked on the donor.. spongy and took 2-3 pumps to engage (I wouldn't know what worn rotors/pads looked like.. so i should probably just rebuild these for safety purposes any how)
tires are too large to fit the donor wheels. (and the donor wheels are pretty wrecked and rusted looking) I will worry about this after I successfully swap axles.
Lockers: Purpose of truck is to do more trail/rock crawling. I'd like to maybe mess around in moab this summer (6 hour drive).
In what dimension are the tires too large to fit the donor wheels?
Yes, the donor is a 3spd auto and my rig is a 4spd auto.
The stock 85 came with 15x6's, so I swapped to i believe 16x8s or 16x7s (I don't remember now and the size isnt listed on my bill of sale). I had assumed the 81 was also smaller width wise...sounds like I am wrong?
I am shifting while in neutral. Also, in my rig when going from 4 Hi to 4 lo, there is a brief gear grinding noise during the shifting only (Similar sound to shifting a manual tranny with out clutch depressed enough) I also haven't verified if 4wd works in the donor (The light comes on, but not tested.)
While trying to remove one, the shock snapped OFF at the upper shock mount on the undercarriage and woulda hit me had the exhaust not been blocking it's fall.
