corp 14 or dana 70???
Does anyone know the weight difference between the two axles? I've heard that the Dana 70 is very heavy just curious how much. Thanks! /forums/images/graemlins/thumb.gif
I don't know what it weighs, but I just installed one and it is damn heavy... I think alot of the extra weight is in the HUGE brake drums. I am hoping to go to disc's sometime to dump alot of that weight.
Don't forget lockers. The detroit is basically a drop in into the carrier on the 14 bolt. You need a completely new carrier for the 70.
If you want to run unmodified hummer rims, you can get a wider D70 and not have to use any spacers. I think even the widest 14 bolt (van) is still not wide enough for them. Just a consideration /forums/images/graemlins/whistling.gif
