original balzer
I like the looks of the beds on the quadrasteer trucks
We've already had a few discussions on here about swapping axles front to rear and the fact is that you can do it. 10-bolt axles are the clear example. They use the same ring, pinion, spiders, carrier, etc. front and rear and this works at both ends. You just use the opposite side of the teeth. The exception are high-pinion axles. If you flip an axle around, the pinion is now on the opposite side of the ring gear, so you get rotation in the other direction.
sorta stepsidy.I like the looks of the beds on the quadrasteer trucks![]()
i like it also.
