cross over steering arm for dana 60
jstevenj
north Miss.
Hello,
I am adding cross over steering to my Dana 60 front and am in search of the arm required to do this. I have the tools to make the arm but it would sure save me a lot of figuring if someone had a drawing of one I could go by.
Thanks, Steven
Come on, I know someone has one out there.
Thanks for the links but I have the equipment and tools to build my own, I'm looking for a drawing of the arm.
Good luck finding "Proprietary info" anywhere... /forums/images/icons/tongue.gif
Rene
I don't look at this as asking for "proprietary info". If I was emailing OffRoad Design and asking for this type info then it would be propriatary but I'm looking for the person who has made one for his own truck. I know I'm not the only person who has ever "homemade" one of these.
Best bet is to find someone with a cross-over set-up and rip-off the dimensions from that...
Honestly it looks to be a simple piece, and with multiple holes like the Avalanche piece the geometry could be dialed in later. The spendy part is the tooling you need if you want the tapered hole.
Rene
OK, if no one has the whole puzzle, maybe I can get a few of the pieces.
Can someone tell me the taper of the hole for the tie rod end. Also what angle is milled on the end where the tie rod fastens. I'm thinking I'll put several holes in it like the Avalanche like you suggested.
The angle is a 10 degree angle milled into the end of the arm. Taper should be done to match whatever ends you want to run. MJ and BadDog have a ton of great info and part numbers to work with...
Rene
Thanks, now we're getting somewhere. Who are MJ and BadDog? Do they have a website?
I'm planning on using the rod that connects the wheels together - drag link? not sure of proper name. What's the taper on that type tie rod end?
if you have a dif and pitman arm the dims are all in your possesion now.
you have a 60 so the bolt pattern and the hieght required for the upper kingpin spring is in front of you
if you have a pitman arm you wish to use you make the steering arm about the same working length unless you wish to quicken the steering ratio
the taper is ~7deg but nailing hard part numbers for the correct taper has proved to be tricky.
I bought the Snapon reamer that was 'the correct' one but turns out isnt really correct taper, close but not perfect
the one I bought is made from ~1" flatbar/plate with a pipecap welded to it for the kingpin spring seat
Well the local airport may also be adding a red warning light to the top of your truck Mike... /forums/images/icons/grin.gif /forums/images/icons/grin.gif
Rene
the 10 deg thing puts the draglink mount surface near parallel to the axle centre line.
it basically accounts for the kingpin inclination.
If you study the pics from many crossover jobs you will start to see many times the angle is increased beyond 10deg to try and get the drag link rod end in the centre of its travel or even tailor it to be bind free through suspension travel for an individual truck
Here's an example of the 10 degree machined surface into the D60 crossover arm:
Then there's the D60 crossover arm with no machined surface...just flat as the rest of the material:
Notice the binding in the tie rod end, thanks to a non-machined 10 degree bevel in the crossover arm.
as Rene pointed out my beater is a tad taller then the truck in your posted pic, so perhaps isnt a good comparo.
I would look to the MOO 3 link front suspension in the article in tech, and compare it again to a newer image.
Steve Frisbie redid the steering arm angle on his if I read the photos correctly.
I would be tempted to ask him if there is a way to determine correct steering arm angle other then trial and error.
it seems foolish to pay for machining to 10deg and then have to bend it further.
I think he heated and twisted his arm in a press to the new angle but am unsure.
the Ned Bacon SAS chev definitely did the twist as he used an old Dynatrack arm and t is obvious in the pics it has been twisted
*edit- I could be way wrong on Frisbie's ride even the early photos show a lot of twist.
Re: cross over steering arm for dana 60 - taper solved?
OK, I did a little measuring last night. I put an old knuckle in my mill and used two indicators to measure the taper of the hole. One indicator was used to measure the vertical travel and another indicator was placed on the taper. I measured the displacement of the taper over a given distance. I did this on two opposing sides of the taper so my readings would not require that the axis of the taper and the axis of the indicator travel be parallel. After running the math on the numbers it shows about a 7.226 degree included taper. In order for this to really be a 7.00 degree taper I would have to off several thousands on my readings - not likely with a 5 tenths indicator. Then I got out my Machinery's Handbook and started looking at standard tapers. As it turns out a #33 Jacobs taper has an included angle of 7.266. My measurements could have easily been off by a few tenths which would make this much difference in the angles. I'm betting on #33 Jacobs taper and this shoild be a pretty common reamer at most tooling supply houses.
Hmmm, not sure how I missed this post yesterday, but looks like you've got all the info on the arm that I could give (and more).
Russ,
Can you confirm the taper specs. or add info.
Thanks, Steven
