jstevenj
Registered Member
Yes,
you need to be a vender to pimp your products in the forums
Been there done that and won't do it again, the 1 ton ends will break or bend under hard wheeling, I tried them and bent one, broke the other, they are just to long and week for cross over steering.jstevenj said:here's a pic
You might get away with it with heims??, the angle would be to much for a TRE I would think. "Can rod ends handle more angle than dre's?" No, DRE's can handle more angle thats why you see Jeeps running them with straight drag links but they often fail in the strength dept as my picture points out.KidJethro said:Would runnning rod ends/heims solve the DRE angle problem with a straight draglink? Can rod ends handle more angle than dre's?
Actually, I was talking about Drag Link Ends, and I bent and broke the ones shown with hydro assist.jstevenj said:On the tierod ends bending or breaking - I don't think I'll have that problem with hydro assist - the ram is doing most of the work.
coloradok5 said:Been there done that and won't do it again, the 1 ton ends will break or bend under hard wheeling, I tried them and bent one, broke the other, they are just to long and week for cross over steering.
