Cruise control replacement for 76 blazer
hunter29078
Lugoff
I have a 76 blazer with factory cruise control. I know the cable going to the servo is no longer any good. I wanted to know if anyone has any idea if anyone make a replacement that is close to the factory. I know some kits are offered but I would still like it to look close to original. Thanks.
Are we talking about the speedo cable, or the control linkage from the throttle?
LMC has the speedo cables (as would your local parts house, prolly...)
http://www.lmctruck.com/ICATALOG/BZC/full.aspx?Page=39
The "two piece" are the ones for the cruise, IIRC.
I thought the throttle linkage is your basic sheathed control cable, as used on manual chokes, etc.
-- A
-- A
Thanks dremu. Looking at the pictures I am not sure. The servo I have might need replacing as well. I am really not sure about the working of this particular type. The only cruise control I have replaced was in a 97 dodge. The linkage on the carb is all there, I know where the cable go into the servo are in half, and the servo looks dry rotted. I will post some pics this weekend and maybe that will help.
