mr_blasto
Are D60 front axles supposed to have some sort of seal between the axle tube and the axle shaft? I am assuming so, otherwise what prevents oil from the differential from going down the tubes and spilling out on the knuckle and the road? I have my axle assembled but not swapped yet and oil seems to leak from there, so what did I miss or mess up?
I know that in the D70 rear, the oil from the pumpkin is supposed to lubricate the bearings and such on the spindle. This is what I was told at least with a warning not to use much if any grease on the rear wheel bearings.
Someone point me in the right direction please.
