I swapped 14 bolt hubs onto my d70hd so that my WMS will be the same as my dually D60... Running Non recentered H1's. I ordered Disk brake brackets for the d70, but they are way to far from the disk for the caliper to work. Whats the answer?
IIRC, the SRW hubs put the rotor 2" outside of the DRW, which seems backwards. Anyway, assuming you're using SRW wheels/rotors, I think your options are either 2" spacers and 2" longer bolts, which seems kinda hinky, or as mentioned, weld-on brackets.
