Will keep it short: 87 Jimmy currently on 10bolts under the knife today...
Rear: d70 hd,diy kert spring perch,ord 2 1/2 flip,4" lift spring,6"shackle.
Front: d60,tc6" lift spring,...should I use the zero rate in the front or not? I bought it for the exra lift and to move the axle forward, but some friends said not to..will be to high in front..I dont want saggy butt.
I know I can always change it later but trying to save time before I go back to work. I am leaning on not using the zero rate, but I need some input from d70hd users... I was figuring 1" more lift using it...would it be more?
