Score a FREE Membership sticker when you sign up for a Premium Membership and choose the recurring plan.
DaBurb (8 low)
  1. nedceifus
    nedceifus 1/2 ton status Premium Member
    Aug 20, 2015
    547
    747
    Nebraska
    Build(s):
    Headed out to get this thing finally.
  2. 78K30
    78K30 1/2 ton status Premium Member
    Mar 20, 2012
    1,056
    1,014
    Monroe iowa
    Build(s):
    I like the full skid idea. Couple guys that used to wheel with us ran S10 blazers on skid loader tires and went everywhere with a full skidplate largely in part due to being able to just slide it over stufff
  3. nedceifus
    Aug 20, 2015
    547
    747
    Nebraska
    Build(s):
    Man! I was going to part this out but it is too nice. I may have to sell my gravel road rocket & drive this back & forth too work...
  4. Phil513
    Phil513 Freakin' Sponge Premium Member GMOTM Winner
    Mar 10, 2015
    3,653
    2,859
    Las Vegas
    Build(s):
    That thing is cool!
  5. nedceifus
    Aug 20, 2015
    547
    747
    Nebraska
    Build(s):
    It's pretty clean, complete & whoever did the cab chop did a pretty good job. Needs a flexplate, torque converter & Battery & I think it's good to go. I think after that a paint job & some tires & I'll have a great kid hauler.
  6. nedceifus
    Aug 20, 2015
    547
    747
    Nebraska
    Build(s):
    Doah! Sold the new Burb..... back in the same town it came from, 5 hours away. At least i did not unload it off the trailer.
  7. bent72
    bent72 Desert Solitaire Premium Member GMOTM Winner
    Dec 3, 2002
    12,748
    12,015
    colorado
    Build(s):
    Make money?
  8. nedceifus
    Aug 20, 2015
    547
    747
    Nebraska
    Build(s):
    More bad, time waisting ideas...
    bmxbryant9 likes this.
  9. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    11,221
    1,169
    Hooper, Utah 84315
    Build(s):
    Good thought though
  10. nedceifus
    Aug 20, 2015
    547
    747
    Nebraska
    Build(s):
    I was feeling like I needed some more sheet metal work to do because I enjoy it so much so I cut a big hole in the floor to gain clearance for my transfer case. Raised it about an inch & a half. Also cut down my skid plate/transercase crossmember drop framework. A full belly skid worked way better in my head than in reality. Seems like every time I dream up some cool mod I have not seen on other trucks as soon as I start to build it, I realize why I haven't seen it, it does not work! Anyway. Still have to try some stuff here & there.
  11. bent72
    Dec 3, 2002
    12,748
    12,015
    colorado
    Build(s):
    Wondered about that skid, now we know
  12. nedceifus
    Aug 20, 2015
    547
    747
    Nebraska
    Build(s):
    Well, sort of , not really. It was given to me. I sold it for $500 then called the guy who gave it to me & told him I'd give him $250. Gas & pain to pick it up probably ate up my $250. I did get the intake runner that goes from the air cleaner to the rad support off it though! I ran over mine with the lawnmower. May steal a few odds & ends yet.
    bent72 likes this.
  13. nedceifus
    Aug 20, 2015
    547
    747
    Nebraska
    Build(s):
    Aright I feel like I took a step or 2 in the right direction today. Traction bar crossmember in. Works great as a crossmember for my frame & will help support the skid plate. Also puts the shackle below the bar. I was contemplating a fabricated transfer case crossmember & decided to throw up the factory unit for giggles. Turned out that with the transfer case raised, it fit in the stock position, up flat on the frame like it should. The skid plate will cover it & all can remain flush. I lucked out there. I thought for sure I'd have to clearance it for the driveshaft at droop but I think it will work with no modifications. TomWoods built my shaft with a small diameter tube & it makes a big difference when it comes to clearances up there. I've got 6 degree shims from ORD to get my pinion to front shaft angle looking better. This winter I'll cut off the C's & correct my caster. Exaust looks stupid, & it is, but, I was planning on building a system from scratch anyway with a Flowmaster Y I picked up.
    bmxbryant9 and Truckman4life like this.
  14. bent72
    Dec 3, 2002
    12,748
    12,015
    colorado
    Build(s):
    Wow that front pinion angle
  15. 454Sub
    454Sub 5/8 ton status Premium Member
    Apr 11, 2012
    2,383
    619
    Southern Illinois
    Build(s):
    What's your rear DS like?
    I just got mine raised up and of course the 1350 t case joint binds in the yokes.
  16. nedceifus
    Aug 20, 2015
    547
    747
    Nebraska
    Build(s):
    It looks alright but I'll have to get it off jackstands & to town to do some poser flex tests. I'm not running a terrible amount of lift so if it is a problem I'll lower my stance some....... we will see.
  17. 454Sub
    Apr 11, 2012
    2,383
    619
    Southern Illinois
    Build(s):
    Meh, I just ground them down a bit and they are happy now. Good enough.
    Yours a 2 joint 1350 shaft?
  18. bent72
    Dec 3, 2002
    12,748
    12,015
    colorado
    Build(s):
    This is what you want
  19. 1977k5
    1977k5 1 ton status Vendor
    May 26, 2003
    10,151
    262
    Yeah, a lot of people would be jealous of that shaft
    GWeakland620, skunked and bent72 like this.
  20. bent72
    Dec 3, 2002
    12,748
    12,015
    colorado
    Build(s):
    Dont make me blush
    Justin V likes this.
