Dana 300 Blank DIY Clocking Ring/Spacer
4WHEELSUPPLY
Registered Member
VA
Offering a blank (non drilled) 3/8 and 7/8 ring. Will be drilled and countersunk with 6 bolt pattern and milled bore for tight fit on input housing, just not drilled and tapped. Can be used as a spacer or a DIY custom clocking ring, where you drill and tap your holes exactly where you need them. Here is a pic. will be adding to product line on website later today. $30 for 3/8 and $40 for 7/8 Mounting hardware included. FREE SHIPPING!
