Dana 44 drum to disk?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Jimman207, Jan 2, 2021.
  1. Jimman207
    Jimman207 Registered Member Premium Member
    May 11, 2019
    16
    3
    Wilmington nc
    I have a 70 dana 44 up front with drums. Anyone know if I can replace the knuckles bolt up disks and use all the same internals? (Hubs, spindles, shafts) or is there more to it. Found several axels to swap in from mid seventy's and eighty's but the gearing is different. Looked into swapping gears but looks like all the advise is find one with the correct ratio(3.73)? thanks
  2. bradshawtech
    bradshawtech 1/2 ton status Premium Member
    Jul 28, 2007
    1,079
    89
    Monte Vista, Colorado
    Build(s):
    Replying to see what the experts say, I have the same questions about my 68 K20.
  3. bp71k5
    bp71k5 3/4 ton status Premium Member
    Mar 31, 2006
    7,928
    1,942
    Knoxville, TN 37922
    Build(s):
    you may not even need to swap knuckles. Just the spindles out should be enough. Be careful about using old spindles though cause I remember early models sometimes had a smaller spindle size that doesn’t work with later parts. Not sure where 70 fits on that spectrum.
    edit: cancel that. I’m thinking of the swap from 6 lug to 8 lug. No idea about drums for sure, but I’d be surprised if the axles aren’t the same from the knuckles inward.
  4. ashman
    ashman What's a pigeonrat?? Premium Member GMOTM Winner
    Mar 1, 2011
    5,238
    4,812
    salt lake city
    Build(s):
    3
    May need to post about this in the Garage forum for more eyes to see it. I'm pretty sure that replacing from the knuckles out will work just fine, but I've never done it myself so I can't be sure.
  5. Wes Harden
    Wes Harden 1/2 ton status Premium Member
    May 28, 2005
    2,990
    3,063
    Southern Califorina
    replacing the knuckle would depend on the axle being an open knuckle or not, Iirc the 1gen had open knuckles, but many drum brake 44's were closed knuckle. If closed knuckle you will need another complete axle housing.
    bradshawtech likes this.
  6. sweetk30
    sweetk30 let it all BURN ! Premium Member
    Nov 1, 2004
    35,844
    12,416
    horseheads , ny 14845
    Build(s):
    4
    had a open knuckle drum front under my dads old truck .
    and knuckle is cast different to clear the body of the caliper . so yes you will prob need knuckle out and some spindles the bearing size is different .
  7. bradshawtech
    Jul 28, 2007
    1,079
    89
    Build(s):
    That’s, that. I’ll need a complete axle, mine is closed knuckle. Is there any value to mine other than keeping it original?
    I haven’t checked the ratio tags but on my drive home from the shop this weekend after pressure washing the truck it seemed like my top speed is going to be very conservative.
    Larry likes this.
  8. Wes Harden
    May 28, 2005
    2,990
    3,063
    Southern Califorina
    Many older 4x4 had 456 so if you had 30 31 inch tires then 55 would be pushing it. I put the ring carrier and pinion from a closed knuckle 67 first in an open knuckle 76 ford. Parts swapped no issues.
    Chevy d44 shouldn't be to hard to source, get one with disc brakes.
  9. Jimman207
    May 11, 2019
    16
    3
    Wilmington nc
    Yes its an open knuckle. So I can just use a mid seventy's d44 and swap in my pinion gears? I mean just pull the pinion and ring gear without any special tools or presses and swap? Videos I have watched on changing pinion gears looks like alot to it?
  10. 76zimmer
    76zimmer Flyin Rat Staff Member Moderator GMOTM Winner
    Nov 14, 2005
    26,716
    10,259
    Kzoo, Mi
    Build(s):
    You would need to do a ring and pinion gear setup to do it right. Not just a plug and play part!
    Wes Harden likes this.
  11. diesel4me
    Jul 24, 2003
    28,155
    10,266
    Massachussetts
    Just get a complete 72 up disc brake front axle from a salvage yard ,unless your proves to be an uncommon ratio like a 1/2 ton with 4:56's the 73-up trucks didn't use very often ,you can likely score a complete take out for about $300 or maybe less...
    I see many 1/2 ton axles selling cheap because they are being upgraded to 1 tons around here...
    I believe the GM corperate 10 bolt front ends they started using in 1977 or so still bolt up the same,but some internal parts differ from a Dana 44,so its best to know just what year & model the axle came from so parts needed in the future can be had without guessing.
    It is "involved" swapping just ring & pinion's around,you need a bearing press,and dial indicators,the skill to use them all,and sometimes even if everything is done right there are still problems.
    Swapping in a complete axle can be done in an hour or two,hardest part is getting the u-bolt nuts off ,you may have to buy new u-bolts ,cutting them off saves a lot of labor & time and you aren't really supposed to re-use them anyways..
  12. Wes Harden
    May 28, 2005
    2,990
    3,063
    Southern Califorina
    I try to always use new u bolts @$40 from most spring shops. @$80 for HD from ord. So if you get new and old ones are rusty cut'm off with a sawsall or whatever works for you.
    Nice to have an old I bolt or 2 for mock ups thou.
    Yes when I swapped the d44 gears I had to set pinion depth and back lash. Ran a pattern. The housings are never exactly the dimensions, 004 or .008" in the housing will change the pattern.
  13. Jimman207
    May 11, 2019
    16
    3
    Wilmington nc
    I have located a 1976 dana 44 with disks 3.08. I am going to swap everything axel shaft and outward. It will probably take me a while to get to it but I will post if successful!
    ashman and Wes Harden like this.
  14. 19Tim69
    19Tim69 1/2 ton status Premium Member
    Dec 29, 2018
    224
    243
    NorCal
    Build(s):
    I know from the spindles out it can be done but why would you?
    The older drum axles are not as good as the later disc axles.
    Here is a good read on the difference if you want to check it out.
    http://d44tech.com/69-72_front.html
  15. bradshawtech
    Jul 28, 2007
    1,079
    89
    Build(s):
    Handy, thanks
    19Tim69 likes this.
  16. 19Tim69
    Dec 29, 2018
    224
    243
    NorCal
    Build(s):
    I swapped in a 76 Into my 69 once I found that the whole unit was better than the drum unit.
  17. LVJimmy
    LVJimmy 1/2 ton status Premium Member
    Aug 22, 2005
    374
    86
    Lost Wages, NV
    Some D44 had different length axle shafts.
  18. 19Tim69
    Dec 29, 2018
    224
    243
    NorCal
    Build(s):
    Yes For GM the K5 & the K10/20
  19. Stephen
    Sep 15, 2000
    4,515
    955
    Carbondale Colorado
    $45 for ubolts if you want just the Ubolts but a good point to remember here is that a lot of the early axles had 2.75" tubes and they'll use different ubolts and plates compared to the later trucks. Going to the later 3" tube is nice and using the later model plates with swaybar mounting points gives you some options for putting a swaybar on the truck pretty easily if you want.
