Dana 44 pinion seal leaking
hunter29078
Lugoff
The pinion seal on my 44 is leaking. Can't seem to find one at my parts house but found these for the jeeps online.
http://www.jeep4x4center.com/product-information.asp?number=998092N
Not sure which one I need but figure I would just buy both since they are inexpensive. Anyhow I am pretty sure they will work because thee 44 are all pretty much the same right (excluding the diifernent gears for front or rear, nad axle shaft lengths)?
Also can the seal be removed and replaced from the driveshaft side? If so how, once the yoke is removed how can I get the seal out with the pinion still in? Another thing that has me confused is the LMC dana 44 diagram look like a piece between the seal and the yoke, but offers no replacement. If this is so I didn't want to damage it. Just wanted to get some imput from some one with more experience, before I started.
