I am removing the axle shafts and got the pass. side off but cant get out the driver side long side. IT should slide right out or does it have a pin inside the carrier. I pull it and it dosnt budge.
It shoudl slide right out. Sometimes the axle yokes hit the opening of the knuckle, make sure the knuckles are really straight. You might try rotating the axle too.
Pry on that suka with a medium pry bar. I'm guessing the splines on the shaft have twisted some. Does this rig run cut boggers and have some horsepower? Course that usualy happens at the stub. hmmmm.
