Dana 60 reassembly help
sandawgk5
3/4 ton status
Kitsap County PACNORWEST
I am reassembling my Front 60 and I do not have the gaskets for the kingpins on the bottom or the covers on top. My question is do I have to have the gaskets or can I just use oil resistant RTV. If I do need the gaskets for preload reasons or what have you can I buy them at autozone or the like or can I make my own gaskets. If the right thing to do is buy the gaskets that is what I will do.
Thanks
Ira
I've always cleaned both surfaces...then greased them...
I'm curious to see what other members have done myself.
I was kinda thinkin that cause both surfaces are machined with no nicks or cuts so it should seal pretty good. Also it is not like the grease is gonna "flow" all that much is it.
Use rtv, I put mine together with gaskets but wouldnt worry about it otherwise. I never use gaskets on my diff covers and never have leaks.
