My brother has a Dana 60 in his truck, po used the block under the steering arm cap to correct the steering. It sheared the studs off clean at the knuckle the other day.
He is not very mechanically inclined and is a medically disabled vet so cannot afford a crossover system. I'm traveling to fix the truck for him. I sourced a new drivers side knuckle and ordered a drop pitman arm from ORD . The knuckle I found is missing the studs. I will not be putting the block back in.
Can anyone point me where to get the stock size drivers side studs and nuts for a Dana 60 steering arm?
All I seem to find are for high steer, crossover or for the stupid blocks.
