Dana 70 - 4.56 gears
jjlaughner
3/4 ton status
Indiana
Dana 70 - 4.56 gears - Good shape, can post pics Sunday, these are extras (I'm installing 4.10's tomorrow). These are not thick gears, you will need the correct carrier or spacer.
$60 plus ship
http://coloradok5.com/forums/../photos/data/500/gears4.jpg
bump again
anyone anyone, is this thing on? :ears:
1-tonmudder said:
Ill trade you a set of 60 calipers for them. If that works for you post some pics of the gears.
D60 is pending, so I don't need the calipers now... Disreguard the earlier PM.
make an offer or I weld the the ring to my rat rod (when I start building it) for an ashtray :weld:
I might be interested in the gears. I'm going to check on a D70 this weekend. If I get it, than I would definitely like the gears. How much would it be to ship to 80831? Thx,
Z
Z
should be $11 and change, call it $60 shipped. These are the factory gears, not the thick gears; if the axle your getting has 4.10's you will need the 4.56 carrier....
Sounds good,
I'm pretty sure it currently has 4.10s. I'll start hunting down the correct carrier. Thanks,
Z
