dana 70 kingpin open knuckle front
Meh, rear centersection with front tubes. I wonder if it is from Dana or custom? I have been eyeballing a HP Dana 70 Chevy centersection with the cast perch for my truck.
It must be from a 400 series , or its not factory, Dodge used the same spring pad spacing as GM
I've seen lots of D70 fronts in manlifts. if you;re around enough of them you start to notice.
