DANA 70 stub spline specs
sandawgk5
3/4 ton status
Kitsap County PACNORWEST
I have a set of factory 60 slugs that I intend to run as is but when I go to 35 spline stubs I want to broach the slugs I have to 35 spline. Problem is I do not know the pressure angle of the splines or the shape. I could mic the splined area to get the diameter but I need to know what broach to use or to tell the machinist to use to punch them out.
Any info you guys could give would be great:D
Dik
let the machinist see the stub shaft splines, he'd prolly know what he needed, he may even need a shaft to trial fit the slugs anyway
