I have an tip for anyone swapping out the yoke on a Dana60. The socket required is a 1-5/16". A 12pt socket won't fit down into the yoke, but a 6pt socket will.
Luckily I have both. Here's the back-story. I swapped out my 1310 yoke for a 1410 flavor. B_to_C had done the swap a couple months ago in my shop, so I thought I had it all squared away. We had made a yoke tool that bolts to the yoke to hold it while removing the pinion nut.
When I went to do my yoke the first problem I ran into was the socket wouldn't fit in the center hole of our tool. Then I realized the socket wouldn't even go into the yoke far enough to reach the nut. The outside diameter (OD) was too big.
Then I remembered we have another 1-5/16" socket in one of our crane trucks. I pulled it out and realized the difference. The socket I was first trying to used was 12pt and the other socket was 6pt. The 6pt socket has a smaller OD.
The 6pt socket fit into the yoke perfectly and it worked with the tool. Obviously this was the socket B_to_C had used to do his yoke swap.
So, if you're buying a socket to do this, make sure you get a 6pt socket. Or at the very least, try to verify the OD of the socket will fit in the yoke.
