So finally got wife's 67 Suspension from Early Classic Enterprise on here truck went smooth looks great!
But then there is a problem! I got 5 lug axle shafts from CPP over a year ago and did not check to see if center of the hub on axle shaft was same as wheels ( 83 slots from C10). Guess what? The center hub on her wheels is to small by 1/4 maybe hair less, so wheels do not track straight/sit flush.
How the hell do I get out of this jam? I know could turn axle shaft center portion down but $$$ then could open hole up in wheel but then $$. Are we set on these wheels, I have no idea till she see's her truck together which will be a while as body work and paint are still need. I need this to be a roller to move it around.
So what should I do????? No use in spending $$ if she might not like wheels in the end. Could make do then spacer right?
Think I am over thinking this as I found this out less then 45 mins ago.
