diesel fuel leak
Discussion in '1982-Present GM Diesel' started by 6.2L Jimmy, Feb 2, 2002.
  1. 6.2L Jimmy
    6.2L Jimmy 1/2 ton status
    Jan 2, 2002
    164
    Montreal,Quebec
    Hi Everybody.
    Wierd one, on a model 80 fuel filter system looking from the front of the truck the fuel filter base plate which mates to the fuel filter is leaking from a wierd place. Just above the upper most fuel line inlet on the side of the base plate there is a hole cast in the base plate and I am leaking from there. Does anybody have any Ideas or has this happened to anybody else?
    Mike
    1989 GMC Jimmy 6.2L 4x4,1969 Camaro Z/28 502 C.I. B.B.C.
    BLOOD,SWEAT AND GEARS!
  2. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    OK I'll bite. Model 80? Are you referring to the "box" style filter? I never heard it called that, before. If it is the box they are noted for having a leak (usually just air) at the pressure sender that tells the driver when the filter is clogged. The GM bulletin fix for this is remove the sender, tap it NPT, and screw in a pipe plug. Presto no sender/no leaks.
    Real trucks don't have spark plugs!
  3. 6.2L Jimmy
    Jan 2, 2002
    164
    Montreal,Quebec
    Hey all,
    Well I changer the fuel filter block and all is well now.
    Thanks for the help.
    Mike
  4. knudel
    knudel Registered Member
    Aug 26, 2002
    48
    Salem, Oregon
    Maybe dumb question... what is NPT? I'm having the same issue- it seems to be the round thing with foam over it. the foam fell off, it's for 2 rectangular holes in the round things and 2 wires coming out. so... jb weld the holes, or how does it come out to tap and plug it?
  5. tRustyK5
    Jul 23, 2000
    37,300
    2,924
    E-town baby!
    Build(s):
    National Pipe Thread...
    Rene
  6. knudel
    Aug 26, 2002
    48
    Salem, Oregon
    Aha!! And what is that? Grin
  7. tRustyK5
    Jul 23, 2000
    37,300
    2,924
    E-town baby!
    Build(s):
    Pipe is measured by it's inside diameter. So 1" pipe would near to 1.375" outside diameter and 1" NPT would be near to 1.300". So pipe threads are commonly much larger than you'd think.
    There is also a tapered pipe thread...which is tapered if you can believe it/forums/images/graemlins/grin.gif
    Rene
