quicker said:I was thinking of using unimog axles on my blazer but….the limit of the top speed is an issue. So I was thinking modified ford 9 inch or some other combo that is small but tough. Yes I want 44 inch boggers .
boz42 said:Any front end that is the same gear ratio, again very open question. If what you are actually wanting to know is what is comparable strength wise? It would be a dana 60.
What kinda top speed you looking for here? I see you said mogs wouldn't work. With 44's & overdrive I wouldn't think it would be a problem.
quicker said:Well since the dana 70 was also Found in the 1 ton Chevy I figured I would buy it. So I have a 1979 ford dana 70 with a power lock. Not a "real" locker.
I am not sure if it is a regular 70 or the u type but I really don’t care too much as a dana 60 is overkill so I figure the weakest dana 70 is about as strong as a good dana 60.
I am going to rebuild it for abuse but wanted to know where was the best resource for parts and information. I figure a Detroit locker, molly axels, and so forth. The gears are 4.11.. So now I need a dana 60 to go with it. What are they worth? What type do I need to optimize fitting my 75 blazer? or if there is a dana 60 thread that is particularly good could you forward me to it.
Thanks.
imiceman44 said:The D70 U is the one that has a smooth bottom, if yours has ribs or anything then it's not the U, That is the only good thing about the U otherwise it's just another D70
quicker said:anyone?? or where?
imiceman44 said:As I stated above, the U has a smooth bottom, no ribs.
That's why people like it, no need for shaving it to get a sliding diff, and has better clearance.
quicker said:Where do I identify BOM numbers?
Date 5 11 7 C6 Bom 603718-8
the tag on the diff cover bolts says 603718-8 L S
I am pretty sure its a d70 u but the casting only says d 70.
The former owner said it came off a 1979 ford " utility" vehicle.
I went to Dana and it came up with no answer.
Help.
