Which says Dan is correct. Only the pump of the HMMWV has fuel solenoid with 24V. I installed recently such a pump into a M1009 and used 3 hours for finding the error. The engine didn’t want to start...
My question was, because I can’t determine different performances in practice. Only models with internal EGR are clearly slower.
With my own engine I’ve large problems. It starts very badly with cold weather. I must one minute glow, then by hand far glowing and start. After 15-20 seconds the engine begins to run, but very hard and my neighbourhood is located in bright smoke.
I checked the fuel pipes for leakage, found no bubbles in the return, and controled the low pressure pump (sucks more than 12 in Hg and push 8 psi). With the injection pump (DB2) I’ve my problems:
Can I measure the system pressure of the pump, and where? How highly does the pressure
has to be?
Is there an increase of the fuel amount for cold startings?
How much is degree before ATDC the beginning of injection?
I ve seen that te marks on the pump flange and the front cover was in a line, so the pumpe should be on ATDC. Now I placed the timing a little earlier (0.15 in to the right) and the engine runs many more softly. But the start problem only changed. Now the engine starts faster but idles not on all zylinders for one minute.
I hope you have still ideas.
