RollinKaos
Ok here is the situation. I have a 87 half ton burban it has bad bearings on the passenger side front. I have a 77 K5 that is just hanging around. I was considering swapping out the Dana 44 and 12 bolt to the Burban. One reason is the K5 diffs are in better shape. The other being the K5 has 3.73 gears instead of the 3.08 in the burban. I want to run 37" tires at least, ideally I would step up to 3/4 axles but I am just trying to get rolling for now.
Is there any advantages/disadvantages to doing this. I am assuming that as far as strength goes it is a push. I am thinking the biggis advantage would be the lower gear ratio.
BTW its a 350/700r4/208 set up in the Burb.
