R
RIPPEDK5
Guest
I recently got my truck up and going ( 1982 k20 with 14 BFF) it has a disc brake conversion in the rear from ORD. I have an adjustable proportioning valve in the rear and is adjusted to maximum brakes. I have 38.5" tires and all the brakes work but the rear just doesnt hold well.. The whole truck stops like a fully loaded tractor trailer truck. Everything in the system is new. (new lines, calipers (front and rear), rotors (front and rear) and pads (front and rear).It just doesnt stop well... The brakes should be more than adequate for 38.5" tires and it should lock the brakes up....Im at a loss, cause everything is brand new..any thoughts?
