wildmandave
what year of calipper do i use for disk brakes? i know their off of a Cadilac- Eldarodo. im wanting e-brake. thanks
i checked out the Eldarodo one's and the are smaller than the 3/4 tons chevys. so i thougt maybe i was looking at the wrong ones. thanks
someone used wrenches for the levers.. and some kind of garage door spring and it worked......
i was told they were clutch return springs![]()
The caddy calipers are considerably smaller than the front 3/4 ton calipers.
Let me clarify that. The 76-78 caddy eldo caliper piston is smaller. The caliper body and bolt spacing is the same as a 3/4 ton 4x4 front caliper. Did I remember that correctly?
I didn't know that the caddy calipers had an ebrake capability? Can someone elaborate on how it works?
LOL! I am just worried about blowing a line and having absolutly no brakes. I would rather have some kind of way to slow down than not. I would get the caddy brakes for that reason only. Parking brake would be more important to me if I had a manual tranny but I think my parking pin in my th400 should keep me put. Its pretty flat in kansas!
