Yeah...[/quote]
I did take your advice (most of it anyways) Mikey but I didn't, for some reason, include the bushing bolts in that equasion.
I tried as Paul mentioed above to loosen up the bolts to slack everything up and when I put my Crapsman impact on the highest setting in reverse those little fockers still would come loose. If I worked at it with the impact they porbably would eventually back off but I can only get to 4 of the 8 bolts with the impact.
I think I got it figured out though. What i did was take my 90* die grinder and just oblonged the two holes in the engine mount. I suppose this really shouldn't affect anything. Now I just have to take the powersteering pump off to get the bushing bolt in the hole. Should work out just fine. Now it will be the first time ever taking a p-steering pump off
BTW, just so everyone knows, The fitment, IMO has nothing to do with the quality of the x-member. My rig is 38 years old and with all the settling and frame twisting, etc the blazer has gone through, factory tolarences are sure to be off by a bit.
