Dmax in a 72 blazer
it was a fun project, started with a 300.00 ex forest service truck, that was a good non rusty roller, the truck originally had a inline 6, 3/4 ton, long bed on leaf springs. I got it, did custom motor mounts, put a big block, t-400 set up, cut the frame, swapped a coil/trailing arm rear suspension with adjustable track bar and drop coils then a 12 bolt rear. Up front I used new coils, and drop spindles and converted the truck to 5 lug. Boxed the whole frame, moved the brake booster and cylender down on the frame, used a 69-71 k5 tank in the back. Capped the body where I cut it, gutted the doors, capped the hoes where the windows used to come up through. In the interior I smoothed out the dash holes, door holes and cleaned it up. redid the gages and kept the original stereo and added some 2002 escalade full power seats.
got to drive it, kill a rear axle, a u-joint or two and tranny then sold it:doah:
I used to like it when hoe's came through the window of my rides. Why you cappin' 'em? :wink1:
Seriously though, I like the 69 style body lines on the hood in that one pic. I'd like to get one of those.
no pics allowed
Cant do anything but post reply here in this thread.
srry. I am working on a pic host setup and when done ill make links:D
Use photobucket and the img tags photobucket provides...dirt simple and gets the pic's imbedded in the thread here.
Rene
Sorry Ive been gone a while things been hectic. I used a 205 tcas adapted myself to the Allison. The front axle will be a D6o driver side drop. Pics of that to come.
I will post new pics soon It runs. Ive driven it Ive mounted the light bucketts, mounted the core suppourt to the fenders and fabd the hood latch, Ive got the abs mounted and lines run, Plumbed the hydroboots and steering, the factory fuel tank (aftermarket 40 gal job) has been modified to accept the duramax factory pickup-sender unit assy, The SUCK part is 2 injectors took a crap its been sitting to long ive got to pull them and fix it, I have a B&M Quick silver modified to work on the ally, The AAM axle is also in the rear with a 1350 cv at the Tcase and 1410 at the axle,
anny Q's Il be glad to answer and check the sit more often
