rufusbooth
Sounds like you can get it done yourself! I have done many a project using my own circuit boards. I am running my blazer on megasquirt as well using all the stock sensors, trigger wheels, and COP hardware with an LQ9.
The problem you might run into is the size of the board. The biggest pre-sensitized board I have ever come across is 12 x 12. Those go for about 20 bucks. You might have to do some creative thinking and break the board into two different boards with a cable between the halves. Careful consideration of power and data lines would have to be considered. But, it is totally doable and way cheaper than 400 bucks.
Rufus
Rufus
