Do it yourself traction tread on nerf bars?
dremu
Officious Thread Derailer
East of San Francisco
Wanna put some no-slip grip stuff on my nerfs ... fear not, it's not my 'wheeler, it's for my DD-ish K5 :D
Anyway, I was thinking I could do some like spray-on adhesive and then some sand ... any other ideas as to a cheap & easy way to add some anti-slip to slick metal?
-- A
Around here the local hardware stores sell adhesive backed non-slip "tape". Usually made by 3M; I have used it on nerfs before with good results. It's pretty resonable $!
That's what I put on my slider's topsides. :waytogo: :waytogo:
they also make a paint with sand in it... prolly cost you more at first then tape but you can coat and recoat when it wears out.
I've heard of people mixing up sand into house paint and putting it on stairs, wonder if that would work. :dunno:
They make a sand for paint to, couldnt use house paint though (latex) would have to use an enamel (something like rustoleoum in a can)
pfsh, what, like you've never seen an entire truck painted with house paint and brushes before? Not that I know anyone like that....:o
There is a sand for mixing into paint, my dad owns a true value and sells it by the pint, its more like beach sand than regular playground sand. its a bit finer. But ya its ment for mixing into floor paint for nonskid. What i did when i was painting mine was sprayed the slider then sprinkled sand all over it, then painted over it 3-4 coats to lock it in, Most of its still there 4 years later. Worked pretty good. and doesn't peal off the way some of the tapes can.
Yep non skid tape for boat decks and the like it was the first thing I put on mine, 6' of 2" will do both sides, it's lasted for ever too and is still in great shape.
There's two types of non-skid tape. That with a sand-like finish and one that's more like the bedliner stuff. IME the bedliner-like stuff works better when wet.
If you opt for the anti-skid paint additive & can't get it from your local paint store try a boat place. I know West Marine carries the additive as I bought some to put in the paint that never got applied to the plywood in my roof rack. :doah: :doah:
