do you think this is a 4x4?
I`m going to guess 2WD as well, as I don`t see hubs sticking out of the front wheels.
oh yeah! didn't think to look at that. i saw all the lugs and just presumed it was the hub sticking thru th wheel. :D oops.
2wd.
I'd buy it. Its got the wide D70HD rear.
But since it's a dually you'd probably want to replace the hubs anyway, can't you replace them with 4WD hubs?:confused:
I`m failing to see any reason for this. :confused: If it was even possible, why would you replace 2wd dually hubs with 4WD ones? That won`t make it 4WD, if thats what your thinking:confused:
if it was a 4wd dualie...that doesn't have the solid axle in front your thinking of, it is completely different, but yes in normal cases you can replace the dualie hubs with single wheel hubs.
That isn`t what he was referring to though....
