NM Door handles/internals radiator bracket and cluster.
Mikkelsen
Las Cruces, NM
Looking for the following:
73-76 exterior door handles and lock mechanisms from inside the doors. Can't recall if any 73-87 ones work or the 73-76 ones are different.
Radiator 4 core top bracket. 4 Rubber retainers in good shape too.
1973-1978 cluster with tach and mech oil gauge. With automatic shift indicator and connector piece to column.
Thanks.
I am fairly positive that I have a radiator bracket. I will make sure that it is for '80 and older.
I have a cluster out of a medium duty truck. The fuel gauge is in the bottom of the tach, so you don't have any indicator lights there. But I haven't checked the tach, and it has an electric oil gauge.
You can add the auto shift indicator to any cluster.
I will try to get this tach checked and get back with you.
Thanks. If you have the radiator part I'll take it. Don't worry about the cluster. I'm looking for the more complete to our body style one.
I have this radiator clamp plate. It measures 28.5" at the rubber cushions. I would like $ 20 plus shipping and any fees. If you give me your zip code, I will get a quote when I can get it into a box.
Well I finally got a box and the time to get a quote. FedEx wants $15 to get it to you. If you're still interested, that would be $35 total.
I don't have a set of the pads for the bottom of the radiator to go with it.
