goochieman83
On the pinion and on the transfer case output? You aren't measuring the angle of the shaft itself.
I just set the phone on the driveshaft to get the angle. Best I can do at the moment with this phone app.
I don't think it would be the flex plate, trans was recently rebuilt and after reading some other threads about it, just doesn't match what I am hearing.Cracked flex plates like to make noise under acceleration and de-celeration. The bell housing sends the noise all over the vehicle like echoes in a canyon, and makes it hard to locate.
Yeah I got ya, and eyeballing it, they do look parallel to the ground, very close to 0 degrees.Yah that doesn't tell you much. With a standard drive shaft, you want the pinion angle and the transfer case angle as close to parallel as possible.
And parallel is not saying they need to point at each other. If one is horizontal to the ground, the other should be as well.
That works, but Spicer says only up to 3 degrees of operating angle. He's just a bit over that
CV shaft is the only way you're going to get rid of that.
Will do. I wasn't going to jump into an expensive purchase just yet, I like my money too much. But I don't want to go tearing anything up either. I will check them out first. Didn't seem like there was too much play in them when I checked the other day but I just wiggled the driveshaft around to see.
Yeah I never checker the motor mounts but the rubber on the trans mount is cracked on both side pretty bad. Gonna grab a nice poly energy suspension one if I can.
