Any experience with the Dynomax kit 8905? What exhaust are you running?
Do you have a pipe bender? How difficult was it to fit the custom exhaust?I used that kit for both my k10 and k5 when I still had it. Worked fine, fit fine
When I re-did the truck I bought pieces and fit everything the way I wanted it
I do not have a bender, bought a bunch of pre bent sections. It is a bit of a trick to get the layout the way you wantDo you have a pipe bender? How difficult was it to fit the custom exhaust?
I used it. Would have worked fine but the 4l80e pushed everything just far enough back that I couldn’t make the mid pipes work. So I just used the tail pipe section. The kit is well laid out and fit fine on the ground.Any experience with the Dynomax kit 8905? What exhaust are you running?
Were you able to use the factory mount locations for the pipes?I used it. Would have worked fine but the 4l80e pushed everything just far enough back that I couldn’t make the mid pipes work. So I just used the tail pipe section. The kit is well laid out and fit fine on the ground.
I don't have a document to confirm but I have always seen it that wayFrom the factory did all 400 v8 have dual exhaust?
I agreeFor $700 take that joker to an exhaust shop and get it done.
overpriced at $700?I agree
I didn't say it's overpriced, shipping something like this is expensive. But you should be able to get something like this done at a local shop for that price range, this kit you have to put together.overpriced at $700?
