My dually has dual tanks. But there is an issue with one tank. But I’ve been thinking of putting a single large tank in the front of the bed, and eliminating the factory tanks. Has anybody ever done this?
I’ve see some long haul dually diesels put a big round semi tank in the bed. But I will check.d.o.t rules on gas in bed tank = NO hook up direct to fuel system .
so check the rules first before you do this .
Thought about the burb tank, but I have a wicked heavy duty hitch on the back, no room for a spare. Bed has a 5th wheel set up, so bed is already kinda useless!!i had an issue with one tank on my 89 crew cab dually, turns out getting a new tank and sending unit is not that expensive. i also changed out the crossover valve, way better than losing the space in the bed for a tank,
if i where going to go with a single tank i would get the 40 gallon suburban tank and mount in place of the spare tire
That's a great idea!click my budget beater build link below in my sig line .
i used 2 efi tanks but the driver side is primary and pass side is on a toggle switch to pump over to the left . no need for a switch valve .
