Picking some brains with this one.
Bender has always had a dual plane Pro Products intake with FAST ez efi. I never really questioned it since the combo worked.
I believe the TBI needed a spacer to miss the old EGR. That spacer was an open throat 1/2-3/4" spacer. So technically all cylinders could have been fed by the TBI, though not efficiently because the intake manifold has a split between the two planes.
With the engine in Plank, I don't need nor what the spacer. Would I get better performance from a single plane intake (open throat) when using the TBI/ EFI body? This is a truck engine, set up for grunt, not rpm.
PS> I have not found this style of intake from Edelbrock. It might have to be modified as Im using the TPI straight center bolt heads. Don't need EGR anymore.
Thanks guys!
Thanks guys!
