Easy dual horn wiring question
AJMBLAZER
Better to be lucky than good.
Staff member
Moderator
Paducah, KY
Big Ugly's horn slowly stopped working and finally gave out this Spring. I picked up a WOLO dual horn kit that's basically one high tone horn and one low tone horn with some brackets and wiring.
Each horn has two terminals for wires and then one mounting stud. To hook it up they want me to run a ground wire from one terminal on each horn to that horn's mounting stud.
The problem is they assume I had two horns and simply say to connect each of the factory positive wires to the remaining terminal on each horn and that's it.
I've only got one factory positive wire with a connector and a ground wire with a hoop on the end.
I'm thinking I should just run some sort of a jumper from that wire and then connect the jumper wire to one of the horns and the original wire to the other...correct?
What do I do with the ground hoop/wire?
Gawd I hate electrical ****.:doah::doah:
That will work just fine. Connect the ground loop to one of the mounting studs with the other ground loops.
