That's a good find for higher HP stuff.Found this from Quantum Fuel Systems.
LS Swap Fuel Pump Hanger for 1973-1991 Blazer, Jimmy, Suburban, Performance Fuel Pump System, QFS-H882 QFS
Hello Ed,
8an feed line is 1/2", 6an return line is 3/8" we should have these back in stock in the next two weeks
Blazers and suburbans up to around 700 HP NA are easy to retrofit because you can purchase the 87 TBI tanks and sending units and just swap the pump for a 255 LPH Walbro.
If you need the 400 or 450 LPH, the above sending unit is a good option.
Keep in mind, the internal ID of the pump outlet on a 255 LPH Walbro, is very small, its a 5/16" OD plastic barb with a check valve in it. So if you have one restriction that isn't smaller than the pump outlet and then its wide open (-6AN) the rest of the way to the injector rails, you are probbaly fine. Fuel at 40 - 60 psi has a lot more pressure forcing it than a pump trying to suck it out of the tank where you would need 8 or 10 or even 12 AN as the suction line to the pump. In tank pumps are submerged in fuel and only push the fuel, its a major advantage.
Here are some Walbro (TI Automotive) fuel pump flow charts with pressure (PSI) vs flow (GPH) and at different voltages. A gallon of gasoline weighs around 6 lbs, so if you convert it to lb/hr and use 43 psi and 58 psi as the standard flow rates for most injectors, you get these numbers with a 90% duty cycle. This assumes you have the fuel pump wired to a relay with sufficient wire awg and a full 13.5 V is getting to the pump during operation. If not, you will not get the same flow.
Also, this is gasoline, if you are using E85 you can reduce these HP numbers for 40 - 50% and the 255 LPH is not even rated for E85 fuel, you'll need the 400 or 450, or some companies offer a 340 as well for low power E85 builds. Also, this is only 90% duty cycle, if you want more buffer, use a larger pump. However, remember, larger pumps create more heat, it depends on the application and how often you need full fuel flow, a race rig is a lot different than a daily driver. If you are adding boost you can reduce these HP numbers by 20 - 30%, boost uses more fuel/HP to run the supercharger or turbocharger.
You start getting very high flow and you can use twin pumps, dual 255 or even dual 450s can supply a lot of fuel. Holley offers universal in tank pumps that are dual pumps and bolt in the top of the tank, but require custom cutting the tank, or a fuel cell, depending on the kit. I have some of those in stock along with some Walbro pumps.
https://www.volcanomanifolds.com/product/walbro-ti-automotive-in-tank-efi-fuel-pumps
255 LPH (~720 HP at 43 psi and ~650 HP at 58 psi)
400 LPH (~1100 HP at 43 psi and ~1000 HP at 58 psi)
450 LPH (~1200 HP at 43 psi and ~1100 HP at 58 psi)
A factory sending unit for a K5 is easily swappable to the Walbro because you can get conversion fittings from the GM fittings to 6AN or 8AN from Fragola among others.
However, a truck TBI sending unit just has hose barbs, which requires som other adaptor. I have used 45 deg double flare brake adaptors, you could also potential use a single flare 37 deg 6AN sleeve and nut, but be careful.
Here is a truck TBI sending unit I converted to a Walbro 255 LPH and AN fittings back in 2009...
