I bought an ac renewal kit from Rockauto to put AC back in the car. The accumulater tank had 2 charge ports. One hit the inner fender so bad the accumulater would not work. Stopped by Volvette and grabbed the correct one.
They wanted $650 for the 4 brackets. Found them on eBay for $178.
System is in. Full flush. Had the condenser out to pressure test.
I wrapped the long tube headers with DEI heat wrap. 6 hours. Sucked.
Is this ok for putting the header back in? Lift arm was in the way.
Tripod stand under the front frame. Ran it up until the lift arm was free.
Tomorrow I should have it ready to fire up. This will also fix the exhaust leak. New spark plugs are going in also.
