Rant on.
I was trying to install the one new front caliper on the right side. Would not go on. Seems the rotor is too tight to the back side. I check the new to old for height, diameter and thickness. Measures the same. So why won't they go on?
If you receive 2 boxes of Power Stop brake rotors and pads from Summit, and the first box you open has this label on it, what would you assume?
Correct part number from my order. Box screams "FRONT" right at me. Rotors have "Passenger Side" or Drivers Side" on them. Checked the hub mounting area thickness. Old is thicker. So there is the difference. Looked up the part number on Power Stops web site.
NOT THE FRONTS.
The other box, after I opened the shipping box, says front also with a different part number. Rotors are labeled "Front Passenger" and Front Driver". WTH?????
I am so tired of going in circles because of others mistakes.
The correct rotor let the passenger front go together.
Rant off.
NOT THE FRONTS.
Rant off.
