engine block heater and coolant removal
wazzabie
Washington State
By removing the engine block heater how much coolant will still remain in the engine?
What is the best way to remove the engine block heater?
What is the best way to remove the engine block header?
Usually for the lugs I used a chisel punshed a hole adn pryed it off, since the heater has something you can grab I would try to pry it off first.
If it breaks off then I would use a chisel.:haha:
I'd say you're still gonna have a few qts left in the bottom of the water jackets. The last block heater I replaced had a bolt in the middle which i loosened until I was able to easily pull out the heater. It had the expanding rubber plug on the inside, plus the element.
Rene
Rene
Ah good to know, like a boat plug.
Ok so I have the OEM 1978 engine block heater removed. I'm comparing it to the newer model. My old one is made out of solid brass. The new part is stamped.
I would rather go with the old one being that it is solid brass.
The nut on it is staked. I'm going to have to find a new brass screw and stake the nut. This is a nice feature as it prevents the nut from getting into the block.
Any one else removed the oem heater and found it to be solid brass.
block heater? What's that lol
do you want to post a picture for me?
wouldn't mind seeing what they look like and where they are mounted
