74kay5
Was that Dcubb's standard crossmember or did it need to be tweaked to work with the GEN III?
As far as the shock mounting goes, you could weld/bolt the Ford towers right to the crossmember plates, that would be stronger than attaching to the frame I would expect. If the Ford towers aren't tall enoungh, you could space the the shocks down by not mounting them on top of the axle tube. You could use the stock lowers or make you own to position the lower shock eye just above and behind the bottom of the tube. Just my $.02.
The lower bar was lowered for the oil pan. I already started to modify one of the Ford towers to fit around the steering shaft when I had the Dana 44 so I might need to buy another one if I go that route. The crossmember side plate is pretty thick though. It makes the fit next to the steering shaft even closer.
always liked the fabtech 2wd shock mounts but they never made a 4WD version that I know of. Maybe Dave or Kurt will pick up the torch.
but im telling you i would love to get my greasy hands on one of these babies! im pulling my motor to install a new one that doesnt knock, smoke and rattle
and have plans for installing a cross member at that time... would be my ultimate pleasure to slam one of these bad boys in! please keep me posted on the latest and when i can put in an order...
