mogulmasher
Registered Member
My truck is making a noise I haven't experienced before. It's a '77 K20 with a 355 built (poorly) by the previous owner. I know nothing of the internals, but have a eddy 600 electric choke, aftermarket HEI, performer eps intake, headers, aluminum water pump, electric fan. Last few days its running poor, like its down a cylinder or two. I've been fighting the #8 intake lifter for weeks....just won't pump up. Ever since running poor its been occassionaly with no pattern to the noise or when it occurs making this horrible knocking sound. Actually more of a crack then knock, like the crack of a .22 being fired. Its very tin-like sounding, not a heavy sound like internal engine noises typically are. I have had a slight ping under load, every since winter began I know I have been running truck pretty lean, just haven't had time to adjust carb.
Also few days prior to this happening truck was popping through carb (kinda sounds like truck sneezing.....when you push it too hard before being fully warmed up, I know likely from lean condition) during warm up.
Thankfully it looks like a body shop did the body/paint and frame looks like it was southern or western truck...this is reason I bought it.
