yellowroket
Registered Member
just picked up an 87 C20 350tbi, th400, sf14 bolt rear w/4.56s. Never been around these engines before and am wondering do they have factory roller cams. What size heads, valves combustion chambers and such. It has a fuel pump block off plate on the side of the block, can you put a carb on it and run a mechanical pump. Also if carbed whats the max lift the factory heads will handle. Thinkin of building it up for my blazer
